bain19
- Feb 2, 2021
- 12
I think my daly bms's are causing me issues when i use them in parralel. when I run a high current load, like an rv furnace or rv fridge. I can see one battery pack take the entire draw/load. If I tell that bms to stop discharging the entire load will move to a different battery pack.
why is one battery taking 100% load vs all 3 batteries sharing some fraction of the load ?
my setup, what I've built:
3 4s1p 12v battery packs.
each pack has its own bms.
all the packs are wired into my RV power center(progressive dynamics), in a parralel configuration using a common bus(not daisy chained).
if the daly BMS's are the issue, is there a bms that works well with neighbors/parralel ?
