I have just installed a 7.5 kwh solar system in my house.
The house has a 3 phase system.
The technician installed a 3 Phase Sofar inverter. After a few days of use, Im only getting 4kW total per day from the solar system, and still 30kW from the grid. (7 hours of full sunshine)
The technician explained that the way the inverter works is that is always takes the lowest producing phase, and applies this power to the other 3 phases.
So while my AC is consuming 4kWh on Phase 1, the fact that Phase 2 is only pulling 40W, means that the inverter will only produce 40W on each phase.
This seems quite incredible, and can't see why a system would be designed to work like this.
The goal of the solar system was for me to reduce my daily consumption to close to 0.
The technician tells me that the only solution is to replace my inverter by 3x single phase inverters.
Is this the only solution? I must add I'm in Thailand where excess power is supposedly not allowed be sent back to the grid. Excess is simply lost.
