I have panels along with a 3 phase inverter and power optimizers. However my home is supplied with single phase power. Is a 3 phase inverter compatible with a single phase supply for an on-Grid system? My worry is that it may be possible to use but I may only be able to use one leg of the 3 phase inverter to supply my house. In doing so I'm worried that I would only be utilizing 1/3 the power generated by my array. As I am assuming the inverter evenly distributes the power to the 3 phases/legs (L1, L2 and L3). If my assumptions are correct is there any way to feed full power to the home with the 3 phase inverter. The model numbers of the panels, inverter, and optimizers are listed below. Spec. sheets are also attached. Thanks so much for any assistance.
SolarEdge P600-5NC4ARL Power Optimizers
SolarEdge Inverter SE20K-US248NNU4
Jinko JKM270PP-60 Panels
