greeksolar
Hello, I'm trying to put together a new hybrid PV system with batteries.
We have 3 phase grid service here, but its extremely unreliable, usually at least 1 phase is down, sometimes 2. The PPC probably won't ever fix it, so don't offer that as a solution please
Most of our loads are single phase, except the large heatpump, swimming pool heater, and the EV charging station. These are all 3 phase.
My question is. can a system be designed, so that the batteries can be charged with only 1 or 2 phases from the grid? We can't go totally off grid, as we would need 150 -200 kwh in battery capacity, which is too expensive, needs too much space, etc.
Is there a way for us to "trickle charge" (probably a bad analogy) the batteries from a single phase? What kind of inverter, charge controllers, battery setup would be required?
Also we are not net metering, since for various reasons the PPC isn't allowing it yet.
thank you
thank you
