Inq720
Odysseus, expert on the Siren's call
I know this isn't really a common Inverter size for most people on this forum. Someone might find it useful.
Got the 300 watt Giandel pure sine wave inverter in and wanted to test it. The premise was that if it really got 95% efficiency running low wattage items (< 100w) I could justify having this for small loads and a 1500 watt Inverter for the short duration/high wattage items.
The test uses...
Results
The test uses...
- a deep-cycle battery
- running through the capacity tester Will recommends to measure DC watt hours drawn from the battery
- through the Giandel Inverter
- through a Wemo Insight Smart Plug to measure AC watt hours used.
- To a load using several light bulbs
Results
- At 71 watts load, I measure 85.2% efficiency. IOW, it uses 83.3 watts from the battery.
- 144 watts, 85.9%
- 279 watts, 90.5%
- The lowest wattage efficiency was disappointing... in that marketing literature says "up to" 95% efficient. I was counting on a relative high efficiency at sub 100w rates to justify having two inverters. I will know better once I test these numbers against the 1500 watt Inverter.
- The good aspect, the Inverter was dead quite below 100 watt usage. The fan does not come on till over 100watts. It uses passive cooling. The case leveled out at 95°F.
- Above, 100 watts, the fan comes on and eats into the Inverter's efficiency. The fan is not loud, but I really don't have another Inverter to compare. I'd say its about as quiet as a desktop power supply fan. The case temperature drops to 78°F once the fan is going.
