Robert Vinson
- Sep 28, 2022
- 28
Hi everyone!
Just figured I would post some info on my system I am putting together along with the house build. I've only seen a couple systems like this but none that are building the house at the same time so figured I would post some info with pix.
The house is a 3000sf "modern farmhouse" style house that is about 1/2 mile back from the main road. The electrical company wanted 45k to just run the power so I decided to just run solar and skip the electricity bill. Everything will be inspected so it will be up to code.
Solar equipment:
60 450w (bifacial) Canadian solar panels which will be mounted on 2 30 panel Sinclair ground mount arrays.
18 EG4 Lifepower batteries...so far.
2- 15kw Sol-Ark inverters
2- Victron lynx distributors to easily add more battery racks or inverters.
TBD generator
House design elements specifically to help with being off grid:
Bryant Evolution Extreme 24 seer HVAC system with 13 HSPF. Variable compressor runs more like a mini split with no start up surge issues.
Accelerator wood burning fireplace with blower to help the heat pump on those really cold (for Alabama) nights
Spray foam insulation
Range/stove is propane
The house will have a pool with a 3hp variable speed pump.
The way I see it..based on my calculations I will have a lot of excess PV power on the sunny days especially with the bifacial panels. I know my battery bank is on the low side but I want to see where we are at first and use the generator when needed and then go from there. I will add as necessary.
I just completed the power shed and I am in the process of insulating it and then drywall. After that I will start mounting batteries and inverters in there. There is a bunch of rain in the forcast so whenever it clears I will be digging the 8 holes for the sinclair mount. This will be interesting because it is a 24" by 7' deep hole for each pole and about 1 yard of concrete each.
I will post progress as it goes. Wish me luck.
Solar equipment:
TBD generator
