When running up against the limits of available fusing/breakers for AIC, you can more accurately calculate the fault current by including the bus bar/wiring resistance between the pack and the fuse/negative bus bar.
When working with multiple parallel batteries in this size of pack, its best to fuse each pack individually as a branch. At the busbar you may need another fuse depending on the wire sizing and your load. In some cases its not necessary to have a main fuse if a single pack dropping out won't cause a cascade blow/trip of the fuses.
