I am pretty sure I know the question to this answer, but I want to make sure nonetheless.
I want to change the batteries of a Piaggio porter electric from lead gel to 32 3.2V LiFePo4 cells. It has a 96V motor, rated at 11kW nominal with up to 22kW for up to 60 seconds.
In this video of a similar project, at 2:30 you can see that the drawn current goes up to 400A, although only up to a very short burst (around 3 seconds).
At 22kW and 96V the motor should draw only 230A max, but I guess the inverter draws more and some is lost during conversion (400A aat 96V = 38.4kW with 22kW motor → ~60% efficiency at that power draw?)
At first I was eyeing a Daly 32s 250A BMS, because I thought 230A should be enough for 22kW. But looking at the video, obviously this is not the case.
Still, most of the time I would be within the 250A specification.
The sales representative (... I know ...) of the Daly BMS said short bursts of 400A should be okay for the 250A BMS.
From my technical understanding, the main problem is the heat dissipation in the MOSFETs. Even though the BMS has a fan, I am afraid this will fry the MOSFETs.
Am I correct in this assumption?
