This goes along with what @Dzl said...... but I still like to over-spec when I can.As mentioned earlier, the voltage rating for a fuse is also very important. The voltage rating is the maximum voltage that the fuse can safely operate at when an overcurrent situation happens. The voltage rating on the fuse can be higher than the voltage present on the circuit, but not the other way around. If a 250 VAC fuse is used on a device that uses 120 VAC, there should be no problem. If a 125 VAC fuse is used on a 250 VAC supply, the fuse will be damaged and the likelihood of arching is great when the fuse blows.
Heh... the quoted article thinks an overvolted fuse will have a high likelihood of arching... I guess fuses do kinda lean over when they blow...If you google around on fuse ratings, you see discussions about building in margin for current... but don't often see anything about voltage other than the manufacturers rating so @Dzl is probably more on target than I am. I have no real reason for a 25% margin other than the fact that Murphy's law is optimistic and Karma hates me. Consequently I tend to over-design and never like to run something right at it's max rating.
(My Alphred E. Newman Avatar with "What, me worry?" is a sarcastic jab at myself)
A 32 volt rated fuse has a ~10% margin over the max voltage you are likely to ever see on a 24V LiFePO4 circuit.... If you can find something DC rated for more than 32v DC without paying an arm and a leg i would go for it. If you have a problem finding something affordable, you will probably be just fine with 32V.
If you think about it, voltage rating on a fuse only comes into play for 2 reasons:
1) When it blows, you don't want an arc forming causing issues.2) Insulation properties in normal operation (You don't want arcing between conductors in normal situations).My guess is the rating is more about the first reason. It would probably have no problem at 100 volts as long as the current stays low.
Even at 32 volts, the fuse sustaining an arc when it blows seems very unlikely unless the fusible link is extremely short.
I just found this at DigiKey:
Well shit...but don't often see anything about voltage other than the manufacturers rating so @Dzl is probably more on target than I am.
From looking at AIC ratings, I think you are probably correct about the reasons and the implications. In regards to point #1, regardless of max voltage rating, from what I have observed Ampere Interrupt Capacity (AIC) is higher at lower voltage and vice versa.If you think about it, voltage rating on a fuse only comes into play for 2 reasons:
They both look good. The first one is rated for 400A max, the Victron is 500A. Either one should work fine.Thanks guys, I really appreciate your advice! I think I’ll try to get my hands on a higher rated fuse but if I need one in a pinch I’ll feel ok with 32V. I have another question too if y’all don’t mind me picking your brains.
I came across these two fuse holder/busbar combos and think I’d like to give one of them a shot rather than using a simpler bus with separate fuse holders in-line. The Victron uses mega fuses and the Littelfuse model uses MRBFs. Any experience with these busbars or words of wisdom in picking between the two? Preferences of one fuse type over the other? I have a 3000w inverter and I don’t really see myself hitting the 6000w momentary surge it’s capable of but plan to use a 300a fuse there in case I get close every once in a while.
Littelfuse 0FHZ0005Z FHZ Series ZCASE Fuse Holder, 5 Stud Assembly | Waytek
Littelfuse 0FHZ0005Z FHZ Series ZCASE Fuse Holder, 5 Stud Full Assembly with M8 Input, 400A is in stock and ready to ship. Order today!www.waytekwire.com
ABYC 2018 said:Fuses shall have a voltage rating of not less than the nominal system voltage.
ABYC E-11 said:Fuses shall have a voltage rating of not less than the nominal system voltage.
