Hello,
I'm soon creating a 16S2P battery from 32 EVE 280Ah cells. I need to hear your opinions (and I'll try to not ignore them ).
Here is my proposed schematics:
The cells will live inside a welded frame, with own tray for each 16S, with silicone insulation between cells and something else electrically rated for floor and sides (not determined yet).
BMS is 2x Seplos 150A 16S.
I want each bank to be easily disconnected so that's why the Anderson connectors, the same is for the inverter.
Each bank has it's own fuse (Bussmann 250LMT), connected to busbar with 50 mm2 / AWG 1 short cable, and the busbar has a Bussmann 315LMT for the inverter connection. Inverter cable is 70 mm2 / AWG 2/0, cca 1.5m.
The busbar specs are not yet know, but it will be a beefy piece of copper bar from workshop leftovers (we do LV distribution cabinets).
All the cable runs and cells will be properly insulated from the welded frame.
The cell trays will be spring loaded to 300kgf.
What I am missing here?
Edit: Ignore the F3 on negative, it should go to positive. Drawing error.
Thanks
Thanks
