Bigbillsd
- Oct 10, 2019
- 197
12 Volts 100Ah LiFePO4 Lithium Iron Phosphate Battery for RV, Solar Marine and Off-grid Applications
Has anyone bought one of these or has Will tore one apart?I finally found the link again to this battery. I saw it last week and couldn't find it again...
HQST
HQST 12 Volts 100Ah Lithium Battery
- Nominal Voltage: 12.8V
- Energy Density: 126.7Wh/L
- Rated Capacity (0.2C): 100Ah
- Minimal Rated Capacity (0.2C): 95Ah
- Internal Resistance:≤10mΩ
- Cycle Life (0.2C, 20±5℃): 80% DOD 2000 cycles
- Energy: 1280Wh
- Specific Energy: 100.4Wh/kg
- Charge Voltage: 14.4 ± 0.2V
- Maximum Charge Current: 50A
- Charge Cut-off Voltage: 14.6V
- Charge High Temperature Protection: 140℉ / 60℃
- Charge Low Temperature Protection: 32℉ / 0℃
- Maximum Continuous Discharge Current: 100A
- Discharge Cut-off Voltage: ≥8V(1S)
- Over-Discharge Recovery Voltage: 9.6V ± 0.2V
- Discharge High Temperature Protection: 149℉ / 65℃
- Discharge Low Temperature Protection: -4℉ / -20℃
- Charge:32~113℉ / 0~45℃
- Discharge:-4~140℉ / -20~60℃
- Recommended:73.4 ± 9℉ / 23 ± 5℃
- Weight: 27 lbs
- Dimensions:10.2 x 6.2 x 9.7 inches
Warranty Information
- 2-year material and workmanship warranty
