Hello, Im looking for thoughts/tips about my battery pack build to a ”car”.
The battery pack will power a 80-160V motor and charged by a solar panel.
I have:
36 pieces 52Ah 3,2V LifePo4 prismatic cells
3 pieces 16s BMS + Master unit (REC)
Those cells will be serie connected.
Total Voltage: 3,2*36=115,2V
Totalt Wh: 52*115,2V= 5990Wh
Now to the part I feel a bit lost:
this is the steps I plan to do. Where Im standing now is that the cells is newly arrived, unpacked.
Step 1: top balance each cell, with a benchtop power supply.
Step 2: capacity test each cell, to check performance and if some cell need to be replaced. Will use (https://www.amazon.com/Vastarry-Ele...x=load+battery+capacity+tester,aps,205&sr=8-3 or similar)
Step 3: top balance the cells, so they have same level before connecting in series
Step 4: connect them in serie.
Step 5: connect and configure BMS.
Step 6: function test the BMS
Done
I will 3d print fixings/spacers and then mount the cells and BMS in a battery box that I will build.
Best Regards
I have:
Done
- Do I think the right way here?
- Compression? Is that needed?
- Is it possible to reduce the top balance time by top balancing 4cells at the same time?
- is Step3 needed?
Best Regards
