Just designed & printed a case for the Heltec 8S capacitative balancer - hope it helps someone!
Heltec 8S Balancer Case by nate_syd
Case for the Heltec 8S capacitance balancer. Allows you to protect the balancer & screw it to a surface to hold it in place. Printed in ASA for heat tolerance, set the outer layers to 10 to make the screw columns solid, otherwise no supports or anything else required. I print in 0.4mm draft &...
www.thingiverse.com
