Can I get a sanity check here please?
I'm about to place an order for some cells to build a backup bank. I need 8S in order to work with an Electrodacus SBMS0. I've all but decided to go with 24 150ah Lishen cells via Michael Caro. These are pretty good $/kwh and are apparently more readily available than the larger cells. The obvious alternative, which happens to be marginally more costly per kwh at the moment would be a 1P8S pack of larger cells (lets ignore the much larger capacity of the 3P8S pack for the moment).
The only thing holding me back is the terminals. The tapped holes on the 280ah cells are notoriously weak and sometimes crooked. I am equipped to helicoil or otherwise repair but would prefer to avoid this. There has been some doubt expressed regarding the current-carrying capacity of the laser welded stud terminals, though these seem otherwise much easier to work with.
My logic is this: By going with a 3P8S, instead of 1P8S, the current flowing through any single terminal would be divided by 3. I would have to cop the extra work and complexity in handling three times the number of connections.
Let's say my peak sustained load is 3000W (it's probably more like half that). At 24V nominal, that would be 125A total, or about 42A through any one terminal. That seems pretty low given the cells can discharge continuously at 75A (O.5C). Spec sheet here: https://diysolarforum.com/resources/lishen-150ah-specification-sheet-w-photo-caro.177/
Picture of terminal attached (M6 on left, which is what I think I would be getting.)
Would you go with the 150s with welded studs or something like this: Vaircore 310ah
