Hi guys, new here, have a bit of experience building small systems but would like to run some numbers through you guys if you’d be so kind to read through them and point out where I’ve gone wrong or could be designed better
So basically this system is to run a detached garage for a car
The loads I have noted down in my garage are
1200 watt exhaust fan to exhaust fumes while the engine is warming up, it is on no longer than 10 minutes every weekend but I allowed 15 mins in calculations. This is an induction load so has a start up surge. 300wh used a day
Rated 1800watt compressor that’s on no more than 5 mins every month but I’ve allowed 15 mins every weekend in my calculations, I assume this is an induction load but I didn’t measure any surge with the clamp meter? Unsure on this. 450wh used a day
There are 5 led lights that pull under 100 watt each so I’ve allowed 500 watt for 2 hours a day. 1kwh used a day
Then there’s a motorised roll down garage door rated at 500watt that is used every weekend but I allowed 15 minutes a day. 125wh used a day.
This comes to 1875Wh a day even though it’s probably abit less I’ve bumped this up to needing a 3kwh battery as a little bit of autonomy which is 250Ah battery needed with a 12v system maybe 2 if I go down the lead acid route due to the 50% usage capacity.
I’m thinking of pairing this with 4x 300watt solar panels totalling a 1200 watt array
And a 3kw inverter with 6kw rated peak as none of those big loads will be on while the other is, only the lights.
Does this all look correct to you guys?
And is there anything you would change or anything I’ve done incorrectly?
I really appreciate any help and thoughts I get on this,
Thanks
Matt
Thanks
Matt
