I am a follower of your channel and find it to be very instructive. Recently a friend of mine brought up a question which would perhaps be of interest for a future video in your channel: If you have a home grid tie system up and working in a 3rd world country in which utility companies treat your home is a xmas tree (power goes and comes), it would be tempting to:
1- shut the main breaker down during an outage and
2- hook up a single split phase (120-neutral-120VAC) generator (batt or gas) feeding your temporarily grid isolated home. This generator would trick the solar inverter into thinking the grid is there... mmm...
Chances are bad things may happen as I believe that if your home´s load does not consume the 100% of the energy your grid tie system produces , the grid tie inverter would try to rise the line voltage continuously until either your appliances, the generator, or the inverter itself break. Can you please give your expert opinion on this ?
