raurre
This was an Item that came from a plant I do work for. I would only use three of the four poles on the transfer switch. It is a prebuilt unit. But the switch by itself runs around $1100. https://www.automationdirect.com/ad...a-_switches/manual_transfer_switches/41504026Why did you go with 4 wires?
Did you have to buy the box?
How much was it?
Thanks.
I bought it for a fraction of that price. Sad thing is, I have almost talked myself into keeping my two pole transfer switch. The more I have thought about it I think I'm going to remove all the ground/neutral bonding screws in the inverters and use a common neutral. So the 4 pole switch may be put in my inventory.
