No they are not. Go to your local grocery store, all absorption.
Walmart doesn't. Fry's Doesn't. Safeway doesn't. Albertson's doesn't. The grocery store I worked in in 1986 didn't.
The ones in RVs are inefficient as hell. They use 5-6X the AC power of that of an efficient vapor compression fridge. Many new RV units aren't even bothering with absorption and include compressor fridges with small dedicated inverters.
en.wikipedia.org
low coefficient of performance (about one fifth of that of the vapor compression cycle). Absorption refrigerators are a popular alternative to regular compressor refrigerators where electricity is unreliable, costly, or unavailable, where noise from the compressor is problematic, or where surplus heat is available (e.g., from turbine exhausts or industrial processes, or from solar plants).
I power my double door Norcold on AC power, and it consumes about 8kWh/day running 450W about 18 out of 24 hours in 68-90°F ambient conditions. A similarly sized residential unit would use about 1.5kWh/day.
I have been making cubes in mine for over 5 years no problem. Matter of fact, never seen one that could not. Not sure where you are getting your info from.
Too often, short timers are not turning them on 12+ hours in advance, AND they load them up with a mix of refrigerated and unrefrigerated items. It can take 24-48hours of near full running to get to temp. Additionally, many RV installations are marginal further inhibiting performance. Eventually, they freeze fine.
Both sides of my double wide sit at about 0°F pretty consistently on setting 3 of 9. The fridge portion struggles to maintain 40°F. I've improved the cooling baffling and added supplemental fans to the condenser, and it didn't make much difference.
Still looking for that propane / compressor fridge you said was in RVs. I am definitely interested.
No such beast. The refrigeration equivalent of a snipe hunt or a jackalope.
Again, I can't stress it enough, RV fridges are VERY inefficient. Propane is just a very energy dense storage medium, and it makes sense vs. trying to produce enough AC to power a residential fridge while boondocking.
EDIT:
here's the last 24 hours of use:
Opened ZERO times for the last two weeks.
