400A DC Breakers
rfbuehler
Grenada, MS
I bought 4 of these breakers but changed the way I was connecting my system. They have never been used.
Two are in original boxes two are open.
230.00 for all 4 shipping included to lower 48 states.
Link to breakers
Sounds like a good deal. Add your location to the listing title as it often helps sell your item.
When I follow the link, it isn't completely clear if it is really rated for DC use ( by the markings on the breaker ) or if the seller is being optimistic about using it with DC.
Is there more info anywhere?
These are basically the same as the Watts24/7 breakers(rebadged). If the insides are the same they are DC breakers because of the “arc chute”. This is what I found inside my 200amp Watts version.
I might have a use for these breakers if they’re still for sale.
Looks like I’m just down the road from you.
View attachment 146621View attachment 146622
Can you explain what we are seeing in those pictures and if they are good or bad. Personally I would only use UL listed breaker or if they are not UL-Listed at least from companies with reputation for build quality. For example i'll trust this used Eaton 400a breaker than I would this new DHool unit.
