vk2emp
- Mar 2, 2020
- 101
These appear to be easily dismantled, and the construction suggests they contain Aluminium encased LifePo4 cells, not a bunch of 18650's etc. They come in a nice steel case too. The BMS appears to be a run of the mill ebay job, but you could easily replace it with a Daly, DIY BMS or even a batrium if you wanted to.
Wonder if they live up to their capacity?
edit: Forgot the ebay link:
Cost wise these add up to about the same price as a set of 100Ah cells from Ali shipped, Plus you get a nice case, voltmeter and BMS thrown in, and the battery assembled. The good thing is that the auction suggests these would arrive in days, not months. If no one has tried one, I'll buy one next week and put it through its paces.
ATG Batteries 150AH 12V Lithium Iron Phosphate LiFePO4 Battery Bluetooth | eBay
ATG Lithium Batteries are designed in Australia. ---150Ah Lithium LiFe PO4 Battery ---3 year Australian warranty ---A grade cells ---Australian designed ---Jaibaida BMS ---Rubber to assist against vibration and external heat Dimensions (mm) 345 x 190 x 245 mm Weight (kg) 16.8 Kg Terminal M8...
www.ebay.com.au
