This is a follow up to my post in the newb forum.
The battery is a 24-125-13, rated 1182 AH at the 20 hour rate. My concern was that I wouldn't be able to push enough amps into with my 6 kW solar array. Question is, if I only ever discharge to 50%, how important is the charging current? So let's say I discharge it down to 70%. Does it matter if I push 100 amps into it, or could I push 20 amps into as long as the voltage gets back to full?
Another way to phrase it may be ask if charge rate matters as along as I get it topped off in a reasonable time?
