Mark Illingworth
- Aug 17, 2022
- 3
Purchased 4 panels two 12v Lithium batteries , 1500W inverter peak 3000W, 60A Charge controller. Had a faulty panel which i had replaced when I teste each panel. Have panels connected in series and parallel as instructed by seller. Also batteries in series for 24v system.
My issue is my inverter has practically exploded twice. The first after a couple of months. I assumed I wired something wrong somewhere. The second one I purchased exploded with in 10 minutes of connecting it to the batteries. Something popped inside and then the whole room filled with smoke. Returned this assumed faulty.
My concern is whether it's the charge controller causing issues with the inverter.
I'm getting 26.4v from two batteries which sounds about right as full battery is 13v ish. The second inverter I got was a larger one because I thought it may be needed so I got a 2000W 24v inverter.
Is 26v from battery causing my inverter to fail when it is a 24v inverter? Seems a little excessive. All cable connections appear ok.
The other factor that may cause an issue is my charge controller appears to be over charging battery. As soon as I connect the panels to the charge controller i get 30v showing and it gradually creeps up. So may be the charge controller is faulty but causing inverter to blow almost immediately, I'm not convinced.
Any help much appreciated!
Kind regards
Mark. I
Kind regards
Mark. I
