Stiffmeister
- Nov 4, 2019
- 92
Dismantling four 12v SHUNBIN Amazon LiFEPO4 batteries because two of the BMS's have burned up. This leaved me 32 large cells.
1. Should I use 16 cells per BMS or will running them 2p be ok?
2. The Overkill directions recommend 2 AWG for the positive lead. So is 2 gauge pos/neg is the max size I need? I ask because I have 4/0 cables that were originally sold me to by a company.
3. If I run two 100A BMS and create two battery banks, would that allow me to go over the 4.8kw limit BMS? I am powering a house and currently have 36 300w panels and a 7.2kw Outback inverter.
I plan on purchasing Temco TH005 and making all cables.
