Dunndeal
SparksMayFly
I’ve been advised to put 2 of my solar panels in series and 2 in parallel to reduce the voltage and increase the amps, which I’ve done. Panels are 4 305 watts. 36.8 volts and 8.3 amps
A little different situation I’d like answered.
I’ve got 16, 90 ah lifepo4 cells wired in series. Very high voltage Low amperage. Should I put 8 of the 16 cells in series and the other 8 in parallel to reduce overall voltage and increase amperage. I bought a Growatt 3000 48 volt. What do you pros say?
