jibberishballr
- Aug 4, 2022
- 35
Hi all,
New here and still learning solar as I go. I installed a 10.2kwh system on the roof and two MPP LV6548 inverters (running split phase) with some car batteries temporarily keeping them running.
I plan on ordering 16 3.2V cells to get a 48V battery bank with 280ah. My general understanding is to find the amperage for your BMS you want to understand your charge and discharge decay rate (1C and 2C is my understanding of these batteries) and max watts you would need. I'm still a little confused on how to do math on what a 10.2kw system should be putting out but am logging data to see real world numbers starting today. I assume that 100a would not be enough as that would limit me to 4800 watts (48vX100amps) but correct me if I'm wrong on how I'm figuring that out.
At the end of the day, I want to best supply my array with the goal of eventually being fully off grid. I believe my array size should be adequate for the kwh I use on a monthly basis (paired with decent storage) and will be making some changes to lower consumption as well. With a system that size I was planning on getting the initial 48V 280ah and possibly doubling up to 560ah in the future. With that in mind, what sort of BMS setup (one or multiple, what amperage, etc.) would make most sense? I've heard mixed suggestions and am a little overloaded with info atm.
Happy for any suggestions and advice.
Thanks!
Thanks!
