Old_Skewler
After working with some forum members and the manufacturer (Sensata) I was able to finalize a solution for my off-grid cabin and lock on a 240V-48V solution design. The package I had was the following:
In any case, I cannot afford to move the specs up the chain line - Outback, Victron, SMA, etc. I just don't have the juice for that. So I am considering moving the specs down a bit. And that land me at SunGoldPower.
From what I can see from my research, this would be a step down in technical support and perhaps quality. At the same time it could also cost significantly less than the Magnum setup.
I guess before entering another rabbit hole of research and manual/specs readings, I wanted to hear from someone with more experience with this brand whether they would recommend it.
I am highly considering either the 4kW 48V Split Phase basic inverter package/charger OR the 6kW 48V Split Phase Solar inverter charger.
Two things I am concerned with:
1. For some reason the literature does NOT mention lithium batteries but deep cycle or starter batteries. I find hard to believe these products do not support different chemistry battery?
2. SunGoldPower support - a few threads on the forum about lack of support.
Any feedback?
- Magnum MS4448PAE
- MagnaSine PT-100 Solar Charger
- Magnum MMP Panel
- ME-AGS-N Genset Starter
- ME-ARC, control module
Any feedback?
