Hi all.
Well i have my 48v 16cell bank up and running with Daly (Non-SMART) BMS.
The cells are marked 280ah 3.29v
Setting up my MPPT system withWatchPower to set Bulk/Float/Min etc settings looking for some advice.
Assume Bulk should be 16x3.29v = 52.6v
Float something a bit lower ie 50v or 48v?
Not sure about min and all the others etc
Not looking to run the cells to their max thresholds unless that is a better/longer life solution that not doing it (really want these to last a LONG time)
Using a pair of MPP Solar 3kw Charger/Inverters to power the bank. And not sure exactly what settings i should configure within that for this 48v bank
( i did find a LOT of info for 12v, but some was conflicting, others appeared to not scale to 24-48v systems, hence my current confusion...)
Thanks in advance!
Thanks in advance!
