Good afternoon all,
I have a smallish cabin in Missouri 640 sqft, it is hot here and the humidity sucks to say the least in the summer. In the winter we can get to negative temps. I run a wood stove for heat so I am good and warm for the deer season and beyond. The cabin is very well insulated from the outside as long as you keep it closed up. I built the cabin to be as efficient as possible. Propane for the stove and tank less water heater. All of my lights are 9w LED x10 (4 -8 hours a day max) but they are never all on at the same time (unless the kids are there). My water pump pulls about 1200w when on and maybe runs a total of 45 mins a day max, the stove hood fan is 40w when on high (maybe an hour a day) the ceiling fans are AC to DC so they pull 39w each when on high x3, 4 -8 hours a day max. I have an exhaust fan in the bathroom which pulls 38w, one hour a day max. A Keurig for a morning cup of Joe and if the kids are there I end up with what seems like 6 or 8 apple devices charging for whatever reason, maybe 3 hours a day on each of those.
Now here is the kicker, I have a full septic, water catchment and filtering system, full bath and kitchen all to make life nice and homey and keep the wife happy, but she will not go stay with me in the summer because it is just too hot, and I tend to agree.
So I would like to install a Mini Split AC unit and be able to run it off of Solar during the day and battery at night an AC unit will not run all the time but I am estimating about 900W on average about 12 hours a day.
Now I’ll say I understand very little about how much battery I’ll need to power this and have a day in reserve. For some reason I just can’t get that part through my head. What I had in mind so far is the following:
2 x mpp solar LV 5048 5kwh all in one systems
https://www.mppsolar.com/v3/split-phase-lv-series/
2 x Big Battery 48v LiFePO4 power walls (5kWh 104AH) each running in parallel 5kWh, 208 AH.
https://bigbattery.com/product/48v-lifepo4-powerwall/
20 x Trina solar 400w mono solar panels (8000w total)
https://www.ecodirect.com/Trina-Solar-400-Watt-Mono-Solar-Panel-p/trina-tsm-400-de15h.htm
So my question for whomever is:
1. Will this system do what I am asking it to do? or am i way off?
2. Will the LV 5048’s handle half of the panels coming into them, 10 to each? or am i way off?
Sorry this is so long, I just wanted to try to answer all of the questions I could think of you all asking up front.
Am I just dreaming here folks or am I going to need like 10x the battery storage to make this happen?
Thank you,
Thank you,
