SuperD
Current setup:
I am using a 48v battery (currently a 60Ah Litime 48v golf cart battery) to supply power to the XT60 solar inputs on an Anker Solix F3800 to supplement solar input on the OTHER XT60 port as the location of this setup gets poor solar coverage, especially this time of year. Yes, the Anker F3800 is NOT "DIY", but my overall setup "sort of" is, as you'll see. I do have a single AC circuit (15amp/1800w) to this location that is currently connected to a 10a 48v charger (from Litime) which is then connected to the 60Ah 48v Battery.
My issue:
The battery charges the F3800 with no issues, but the charger continually runs if I leave it alone (so I have it shut off currently), even after the battery is fully charged. Litime support confirms the charger doesn't know when the battery is fully charged, and I should just "manually turn it off".
My question:
I'm looking for an AC charger (10-15amps) that can be left connected to a 48v battery that can go into standby when the battery is full but will then come back on for a charge cycle when the battery has depleted to some point - not really concerned much with WHAT that point specifically is, just that the charger can keep the battery "topped off" over time without manually turning it off and on. Anyone have any suggestions on a 48v battery and charger setup that can meet this need? I thought the current setup I have would do this (as the standard golf-cart setups/chargers will go into standby when a cart is fully charged), but apparently not...
My issue:
My question:
