sunshine_eggo
Happy Breffast!
I just used a wrench and did them really tight, my wrench didnt go low enough. I ordered a new torque wrench that will work. If the bolts are tight but not torqued right how does that cause a problem?
loose connections cause horrible problems. An effort to tighten them should eliminate most of the issues. Proper torque ensures solid connections.
Moments prior to disconnect, what is:
Battery 1 voltage:
Battery 2 voltage:
Inverter reported voltage:
Does inverter reported voltage agree with voltmeter?
