SolarJenny
Midnite Charge Controller 150Well yes, it will power it.
But the real question is: what are you trying to power with the inverter?
May I ask how you have mixed spec panels wired up?There’s (2)330watt (12)100watt. I definitely will have room for another 330watt and two 100watt panels. Would that be enough to power a 48V/4000watt inverter?
Not what I meant:Midnite Charge Controller 150
cost
Yes, on our property the existing 24V system had 4 12V batteries 2s2p and it was running fine with our current wattage usage (7 cubic ft refrigerator and freezer all day, tv only in the evenings, occasionally running a washer~1500 watts) , but since I’m replacing the inverter I want to take the opportunity to transition into a 48V, so I can get the 400 extra watts. Also, planning for later this year or next year to have additional household using a tv and internet modem ~1500 watts. I also would like to transition to lithium batteries, but I want to ride out the agm batteries I currently have ( so I wouldn’t want to get new agm batteries).Since you had an inverter already - from the original post, you noted a 4024 - was this unit large enough to supply all your loads/needs?
"40" typically means 4kW, and the "24" would usually mean 24 volt system, although I think you said you wanted to go 48 volt on the new inverter, iirc.
If you were happy with 4kW maybe this is all you need for the inverter. It still leaves the questions about PV size and Battery storage size unanswered, but it's a start.
Yes, I see.Yes, on our property the existing 24V system had 4 12V batteries 2s2p and it was running fine with our current wattage usage (7 cubic ft refrigerator and freezer all day, tv only in the evenings, occasionally running a washer~1500 watts) , but since I’m replacing the inverter I want to take the opportunity to transition into a 48V, so I can get the 400 extra watts. Also, planning for later this year or next year to have additional household using a tv and internet modem ~1500 watts. I also would like to transition to lithium batteries, but I want to ride out the agm batteries I currently have ( so I wouldn’t want to get new agm batteries).
1500 "watts" seems like an awful lot for a tv and internet modem. Do you mean watt hours (Wh)?so I can get the 400 extra watts. Also, planning for later this year or next year to have additional household using a tv and internet modem ~1500 watts.
It’s just a rough estimate of an additional home usage. 1500 in the situation where all the appliances are running. Entertainment plus baseline necessities like refrigeratoration1500 "watts" seems like an awful lot for a tv and internet modem. Do you mean watt hours (Wh)?
That would make this thread make more sense in several areas.
~400 watts from running less current in 48V compared to 24VYes, I see.
You can rearrange the same AGM batteries all in series to get 48v, and as you say get the best use you can from them.
If your comfortable with the 4kW, or perhaps 5-6kW to allow for your future plans, the cost difference is pretty small generally from 4 to 6kW.
I am not sure what "get the 400 extra Watts" is from, (?) can you elaborate?
There are quite a few options for 4-6kW inverters, and generally higher cost units will have lower standby consuption, and lower cost inverters will have higher standby consumption. With a small PV array and small battery pack, low standby would be the way to go, if it fits the budget. That is what I would focus on if it were me in your position.
I will second this with 10 years of experience running on outback 100% off-grid. If you want a bulletproof inverter made in the USA that will last, Outback it is, all these Chinese inverters are just OK but don't be surprised with something that overheats, or breaks when you really need it. My experience with Outback support has been amazing you call and talk to someone who has 20+ years of experience every time. Pay a little extra to get quality. CHeers.Get the Outback Radian 8048
It's way better than any Samlex (not even in the same park) and somewhat better than the Schneider..
65 to 70 watts of PV energy is much to little to take care of a 200ah lead acid battery. They will never get the battery charged. For lead acid batteries, you need MORE solar array so you are assured of a full charge in 5 hours or less.
65-70 watts of PV isn't even enough to cover the idle current of most larger inverters. For a 200ah lead acid battery bank, you need at least 2000 watts of PV, and preferably 3000 or more.
What that 65-70 watts a typo? I sure hope it was.
SCAM!Odd Little Device Trumps Solar Panels in the Eyes of Americans
The conventional solar panel industry is at risk of being completely displaced.
And you are part of a fortunate and exclusive group who have the opportunity to witness this firsthand.
By being informed, you will be one step ahead of the trend, as it can no longer be ignored.
This odd little device takes up only 5% of the space needed by regular solar panel systems and comes at a fraction of the cost, being 98% cheaper.
And will cut your power bills by 80% almost overnight…
And when it hits mainstream… it will probably be in every household by the end of the year…
Get yours while you still can.
ShortURL - URL Shortener
ShortURL is a tool to shorten a long link and create a short URL easy to share on sites, chat and emails. Track short URL traffic and manage your links.shorturl.at
