48v using 4 12V 280ah batteries with overkill BMS for 20kw electric propulsion
Josehoya
I’m building 2 strings of 48v battery banks for a 20kw electric motor for a sailboat. I am planning on using a total of 4 overkill 120amp bms components per string (8 total). The Eve cells are 1C 280ah.
What’s the max continuous discharge current for one of these single 48 v strings?
What’s the max continuous discharge current if both 48v strings are switched together?
My max draw would be around 350 amps from the motor and rarely would be done.
sunshine_eggo
Happy Breffast!
USA
4X 120A per string sounds like you're stringing 12V together to make 48V, i.e., 4S2P
120A
120A * 2 theoretically, but likely a little less
Likely a no-go.
16S Chargery BMS with a DCC200A contactor each would get you nearly 400A.
cobratom
I ordered two of these https://www.aliexpress.com/item/1005002997980729.html
for a 48V Polaris Ranger application where I know I will have a constant discharge of about 200A and peak discharge of 600A.
I will run 2 24V setups so one BMS per 24V side.
If I run into issues during testing that causes the BMS to cut out, I will do two banks of 48V wired in parallel.
