I’ve read other discussions on this and the consensus seems to be that 24V is acceptable but 48V is preferred. If you are going with inverters 3000 watts or higher than 48V is the way to go because wire sizes become an issue. Going with 48V also means you need to pay more heed to safety issues with the higher voltages and make sure your switches and fuses can handle the much higher voltage.
Even after reading all of the advice, I am not sure whether to go 24V or 48V but I’m leaning to 24V. I have previously put in a 400 watt system with a 200 AH lithium battery pack in an RV. It works great. I recently bought off grid land in Arizona and I need to get a system in place. I’m currently living in a nearby town paying rent. I’m financing all of my improvements from work as I go. The sooner I get out of the apartment and on the land, the more money I will have for building improvements. With a family, money right now isn’t growing on trees.
I have 12 240 watt panels from San Tan Solar to set up. I don’t have batteries, charge controllers, or inverters yet. I’ve been waiting to buy them until I know what system I am going with.. I plan to buy more panels from Santan In the near future.
Why am I leaning towards 24V?
InitI’ll battery cost for a minimal system is less and it’s cheaper to add battery capacity as I go.
24V MPPT controllers look to be cheaper
24V inverters are a little cheaper and more available
Building seperate systems to handle different power needs isn’t a lot more expensive
I can add components as I can afford it
All that said, I don’t want to be penny wise and pound foolish. If it’s going to be a given that sometime in the next 5 years, I’ll be upgrading to 48V then I really should price that in now. I don’t foresee myself having any single circuits larger than 15 amp. I lived for three years in Baja on two single 15 amp circuits. 2 2000 watt inverters should suffice and I’d like to have them on separate battery banks and even solar systems So a failure in any single component doesn’t shut me down.
So in my situation, what would you all advise?
