ericfx1984
- Oct 10, 2021
- 740
Well it's starting right now.. 16 Eve cells.. these were originally slated to go in the new house that I'm building but for the time being we're living in the RV and I need more power ... With this heat and running the air conditioner 6 KW hours just ain't cutting it
The plan is to initially configure in 4p4s and then to do a quick charge with about 40 or 50 amps until I get closer to 90%, then do a quick reconfigure to 16p and finish up with the lab power supply...
Then reconfigure to 4p4s attached the BMS and do a quick capacity test.. unfortunately the test unit I have only draws 20 amps...
So I might do it a little bit differently I have an additional 3,000 watt inverter... I might hook it up to a heavy load and just use the BMS to calculate the draw and just time it?
