shadowsteve
- Feb 11, 2021
- 265
I'm building two 12v banks using 280ah cells in a 4s setup each with a JBD BMS.
The BMS is longer than the batteries if I use the bus bars and put them face to face (right side of pic) and clamp as normal.
If I put them in pairs and put a clamping rod in the center then the pack suits the BMS length better and ends up a bit narrower (left side of pic). I will make cables to go where the masking tape shows connections.
Any issues with the second setup that I might have missed? I couldn't find any pics of this arrangement although I'm sure they are out there
