Pez
- Jul 15, 2020
- 7
I've finally got round to swapping the two 10+ year old gel batteries on our camper to a 4S LiFePO4 280ah DIY battery.
The final swap happened in the middle of a field but seems to have come out not bad considering.
While it's a bit hacked together, it's working fine, but I'd like to make some finishing touches.
Namely:
To that end and considering that I'm extremely space limited under the passenger seat:
Namely:
- Reading online, it seems best to slightly compress these cells rather than spacing them
- A box around the raw cells, to protect them, hide any exposed wires and reduce risk of shorts
- Battery terminals rather than direct connection to the cells for the 12v system
- What are the options for compressing the cells? Would removing the spacing foam and wrapping the whole lot in Kapton tape be good enough?
- How have you protected your cells? Would some ply or something else be good enough? What about the top?
- Has anyone sourced or built their own battery terminals? (EU based if relevant)
- If I'm removing the battery foam, should I add another insulator? I see some people using cutting boards
