4S2P Battery pack project
waiapasi2006
Hello all.
I got these battery in from the long waiting list.....
These are 230AH eve Cells. A total of 8.
I had top balanced the cells to 3.65 v and built a single 4S pack for testing their capacity.
This is what I have below. I did build a small box to help keep the cells intact.
Yes, did stick them in a milk crate for easy transportation.
My test at first.
used a heat gun.
What threw me off was the 13A on the heat gun vs. what the Dally app was showing 130.7A.
The wat meter showed 1428 watt pulled from the inverter and the clamp meter 130.6A ( Almost the same from the dally mobile app)
I ran this test for about 10 minutes to see if the inverter will hold up.
My question,
Why is the Dally app showing 130.7A vs 13A?
But, I was surprised that everything was cold to the touch.
Edit: Thanks to Forum and everyone here I was able to take on this project!
That is correct. Amps X volts = watts and the heat gun runs off watts:
120 volts 13 amps = 1560 wats
12 volts X 130 amps - 1560 watts
12 volts X 12 amps = 156 watts
EDIT: Seems a little off still. THe inverters I use have 15% losses, so you are showing very, very low losses, <1%. I would think the heat gun shows 13 amps, the inverter would push that out by pulling the 130 amps it needs from the battery pus another 15% (20 amps), so I would think the Daly shows 150 amps.
Second Edit: I have not done much “heat“ testing, but I run thick 4/0 wires for 155 amps for a coupe of minutes, and those wires do not get hot. If I dropped this down to 2 AWG, I think it would. 2 AWG is not rated for that much amperage.
To run a long term load on the same 4S battery, I charged them back up to 14.6V.
My second test was using my refrigerator.
The spec:
Inverter used with the same cheap wires:
These are the number I got as far as capacity goes for this set of battery.
Time: 29:12 Hours
Amp: 9.7
KW: 2.45 per meter.
= At the time of testing the Pack, that was the only item that came to mind. I will definitely change those cheap wires that came with the inverter.
Still a work in progress.
I appreciate your feedback Chrisski.
Thank you.
I still check voltage loss when I put wires on inverters and Batteries, but I have never found that to matter. I just make sure the wires can handle the ampacity. Recommend wiring for the lowest voltage of the system. TEsting we usually do is when the batteries are charged, but battery amperage skyrockets when the battery drifts towards the low state. 2.5 volts per cell comes out to a 10 volt battery. My 12 volt inverter has a 10.5 VDC low voltage cutoff. THat 2000 watt inverter could see 230 amps in that case. THat same 2000 watt inverter would Normally would be 180 amps on a full battery with float set proper.
THere’s lots of charts out there some better, and wire ratino as published by the manufacturer will trump this, but this is what I use for wire ampacity:
On a side note, those are the very same tiles in my kitchen. I would not be surprised if you are in central AZ also,
Still a work on progress.
Thank you.
According to this reference a 2 awg wire would be in the neighborhood of 140F with sustained 155 amps.
140F water is near enough to scalding.
Yes, I downloaded the wire chart as a refence from the resources tab.
Based on the parameters of the Dally setting, that is what I see here as well.
To add to this. I went ahead and made some busbars with some copper pipes I had laying around.
1/4" pipes flatten down. Not my best handy work at the first attempt.
I ran on those busbars on the batteries for 29+ hours to power the refrigerator. I checked in on them from time to time while running and they were cold to the touch.
I didn't see a draw of more than 10A per the dally app and the watt meter which could be the case. The inverter was warm, but I could leave my hands on the surface with no problem.
My plan now is to finally build the 4s2p packs in a box.
looking at 460A pack @ 12V (14.6V charged)
Should I double on the busbars I made?
Thank you.
Thank you.
I saw a 2000 watt inverter in your pic.
If that is the only load...
2000 ac watts / .85 conversion factor / 10 volts low cutoff = 235.294117647 service amps.
235.294117647 / .8 fuse headroom = 294.117647059 fault amps.
There are tables online for copper busbar dimensions by heat and ampacity.
Note that heat shrink on the bars decreases their ability to dissipate heat.
Hello smoothjoe.
I did download most of these needed information from the resource tab. I just have to incorporate them now.
I appreciate your feedback.
Than you.
So sorry to bring this one back up from the past. I didn't want to re-post what I already have here. Due to a life changing event ,my project was put on hold. I'm slowly getting back on my feet and want to continue my endeavor in Solar.
I've now come the conclusion to change my setup to a 24 volt system. The only changes I will be making is:
4s 250 amp BMS to 100 amp 8S BMS
As for inverter, I am leaning towards this one below.
If you have a better suggestion, I'm all ears.
The max I might run on it is a portable AC and refrigerator. Possibly the microwave when needed....
As for wires, I already have 0/4 gauge from my prior setup . A little over killed but you let me know.
Fuse, this is what I have which was never used
Can you please advice if I can replace the 200 amp fuse and use this one instead based on my basic calculation?
or instead of replacing the whole unit, I get just the fuse?
What would you recommend?
Please let me know.
