keithbar1974
- Oct 7, 2022
- 1
In the case of a 50A RV which has 2 legs of 120v but is not technically split phase. Rather than installing multiple synced inverters or one of the expensive or heavy split phase inverters (Victron Multiplus II x2 or EG4 6000EX-48HV) could I use something like the EG4 6500EX-48 and use an adaptor or wiring that would feed both legs from the 1 inverter. Benefits would be true sharing of the inverter power such as 5000w on one leg and 1500w on the other which in not possible with a duel 3000w inverter. Hope that makes sense. Trying to find a solution for 6K watts of inversion on a 50a RV with one inverter.
