mtnvalleylover
Looking to build a system that can run the entire RV, that I can add to over time.
Phase 1
Inverter and Battary Looking at the EG4 6000XP and 2 48V golf cart type battary's. (not sure I need the Rack mount in the RV)
Removing the current charger
Phase 2
Adding solar at least 1,500 to 2,000 watt's.
I would use a generator to charge until completed. Have a small solar at the moment.
Question, is the 6000XP a good choice or should I look at othe inverters? Seems like this would make things much simpler. Other wise it looks like I have to get 2 inverters so I can run both legs at the same time.
On my rig Ihave two AC's that are tied togerther and not sure I can run just one at a time. Looking into that.
I work remotly like most do, so reliablity is also a factor. I have looked at the Victron system and seems like I would need 2, inverters, not sure if the Quattro II 2x120 would work or not.
Thanks in advance. If anyone is using the 6000XP in an RV already your advise would help.
Phase 1
Phase 2
