Carson - Vanlife Rentals
Carson, I build and rent campervans
This is my first post here, but I wanted to share my DIY battery bank. This forum and Will's videos were so helpful that I wanted to share a few things I learned, as well as a few things I created that I haven't seen before (specifically the asthetics of the case). I'd also appreciate any critical feedback or suggestions, I've learned a lot in the last few months and would love to learn more!
Here is my finished battery, total cost was ~$1,400 ($0.20 pWh vs Battleborn at $0.67 and SOK at $0.42):
I build custom campervans and rent them in Seattle, Washington. For one of my upcoming builds I will have an induction stove, hot water heater, a 12v Domestic RTX2000 AC, and 2 electric bikes. I needed a large, cost effective battery bank, in addition to A LOT of storage for the bikes.
I typically use Battleborn batteries (I need rock solid electrical systems), but they are just too big for this build, so I decided to build a custom battery bank - I'm glad I did. Look at the size comparison of my 560ah battery vs. 6 Battleborn batteries (I'm currently building 3 other vans which will have 3 Battleborn batteries each, so I had a few laying around
This battery bank will allow me to have an electrical cabinet no wider than my wheel (560ah battery, 60 amp DC to DC charger, 3000w Victron Inverter, 150/60 Victron MPPT, Lynx distributor, Victron Cerbo gx, fuse block, AC breaker, solar switch, and a weBoost), which will allow for a much larger storage area.
How I built my case:
1. Frame. I used 1/2" cutting board from Amazon and cut it down to size for my batteries. These were then attached with screws and heavy duty epoxy (only compound I could find to glue hdpe together beyond extremely expensive products).
2. Compression: I drilled holes and used all thread plus polyethene tubing to protect the cells from the allthread.
3. Structure: I used aluminum angle iron for handles/to help with compression and the same on the inside to hold my BMSs.
4. BMSs: I mounted 1/4 acrylic to the angle iron above the batteries, velcroed 2 4S overkill solar BMSs to it, and drilled 2 terminals with 1/4"x1.5" busbars for the positive and negative connections.
5. Battery connections: I used 1/8" x 1" busbars for the batteries, heat wrapped to identify positive and negative sides of the batteries. I attached with M6 16mm studs, noalax, and serrated flange nuts.
Here are a few more photos of the build:
Now, onto my learnings:
1. Building your own battery is probably not worth your time unless you do this a lot, are just curious and want a challenge, or need a big battery bank for cheaper than you can buy (although I'd argue some alternatives are better and only marginally more expensive). I spent many hours researching, finding suppliers, deciding on options, selecting busbar/wire sizes, deciding on BMSs, and building a case. Not sure the ROI makes sense unless you do this a lot, which fortunately I will.
2. There is always a better way to build your battery, but it's not always worth it, nor is it a one-way door (you can update later on if you want). I was considering flexible bus bars to allow for expansion/contraction, so many ways to compress/not compress the batteries, etc. At one point, I just decided to make decisions and stop churning, knowing that if there are better ways to do this, someone else will post and I can always change my design.
3. These cells are extremely compact and save a ton of space. I love Battleborn, but these cells take up less than 50% of the space of equivalent Battleborn batteries.
I'll post updates as we install these into our latest build.
