D
Deleted member 1888
Guest
Ok so I saving to get this 5k growatt with transformer, I have seen vids on it and it seems to be a batter way to get 240 over a normal split phase. There is also the fact that a transformer can turn almost any inverter into a split phase. What I do no understand is can the growatt use a backup generator if the solar is not doing the job? I know the growatt has L1 L2 and ground but my generator have L1, L2, Neutral, and ground, how will that work?
GROWATT 5kW 5000ES (USA Model) OFF GRID INVERTER & Growatt Transformer Kit
5000W LVM- ES Off-Grid 240V GROWATT Inverter with Solar Charge Controller + integrated GROWATT Split Phase Transformer for true 120V/240V Split Phase Electricity! The GROWATT SPF 5000W LVM-ES is the all-in-one inverter/charger you need to take control of your energy bill. The 5000ES can work...
www.signaturesolar.com
