chadjones99
chadjones LLC
No, the plan is to leave it in, as It will be on the input side of the inverter ( output side of gen-set ) and only be an issue when running the generator. which is only if I need to charge the battery beyond what the solar is . And even when I do the well is not hooked up , it will pass through the 2 legs of 120 to the RV . This is the main purpose, AS for 48 volt chargers ( which would be fine too ) that can charge at the same rate the inverter/ charger can.... 100 AMPs that's hard to find and price is pretty high. once again this is only so I have pass through 220 to RV , when charging batterys and not have just single phase 120 on 1 leg of the RV. The well will be solely powered by either the inverter off batterys or 220 volt larger generator that will not be hooked up to this system for power ( its loud and only used for well pump )
