6000W inverter pure sine wave
Rico.chen
The BP series 6000 watt pure sine wave inverter is a high-quality DC to AC converter via pure sine wave. The 6000W inverter continuous power 6000 watt and 12,000 watt surge power that provides reliable transformation to AC power from a battery, suitable for 12V professional vehicles, cabins, RVs, and 6kw solar system. This 6000W inverter provide safety Aviation socket support 6000 watt single large load. AC output power be used to power tools like most electric chainsaws, portable grinders, shop vacs, coffee machines, refrigerators, air conditioners, air compressors and pumps and more. DC input voltage support 12V/24V/48V/86V/110V, AC output 120V or 230V and 50hz or 60hz. BP series 6000 watt pure sine wave inverter can be used full load for long periods of time and Provide power protection.
This 6000W inverter also has an remote port(5525), allowing you turn on and turn off your 6000W power inverter. Click here to check the remote panel.
6000 watt Pure Sine Wave Inverter Key Features:
1. Provide 12VDC/24VDC/48VDC/96VDC/110VDC system voltage.
2. 6000 watt full power long time running at a low-temperature design.
3. No static or humming noises.
4. DC low and over-voltage protection, over-load protection, over-temperature protection and short circuit indication.
5. Max 94% conversion efficiency via 48VDC system.
6. Exclusively designed AC output filters for clean power output.
7. No load current <45W.
8. Provide remote control panel. (optional)
9. 50HZ/60HZ switch. (optional)
10.Two year warranty and tech support. (CNBOU Products Support Center)
mikefitz
Hope there are thicker cables for the 12v version.
Mike
