Would like to get 6000xp and eg4 battery for my off grid setup. I have a reliance transfer switch with a delta pro currently. When I try to AC charge my delta pro, which is connected to the transfer switch it will trip my gfci outlet (same circuit as the ac charging outlet). From my google search, it’s about neutral ground loop created. So I don’t use the ups feature of delta pro for now, only use it as a backup.
Moving on, would like to get 6000xp to connect to the transfer switch to backup and offset part of my electricity bill. Planning on connecting the load of 6000xp to reliance transfer switch. My question is, will I encounter the same gfci tripping problem? What’s the correct way to connect the neutral and ground between 6000xp to transfer switch?
Thank you everyone in advance.
Jeff
Jeff
