Rodney hillbrant
What bms 200 amp 48v will communicate with the 6000xp want to build my own 280ah 48 battery
Few videos of the JK Inverter BMS working with it.What bms 200 amp 48v will communicate with the 6000xp want to build my own 280ah 48 battery
BarelyFew videos of the JK Inverter BMS working with it.
It's OK. The soc is not accurate and the 6000 xp doesn't do any float.haha any suggestions? I just ordered JK BMS suggested in this post
Oh darn it, we are too late in preventing him in getting one.haha any suggestions? I just ordered JK BMS suggested in this post
its okay, I have cancelled it, thank you so much about the warnings about JK BMS being abandoned.Oh darn it, we are too late in preventing him in getting one.![]()
It is most of the same issues.its okay, I have cancelled it, thank you so much about the warnings about JK BMS being abandoned.
So it seems like the approach is Victron smartshunt + custom setup to convert VE.DIRECT to PYLON?
For optimal performance, it is strongly recommended to add another EG4 battery if expanding your battery bank. Mixing EG4 batteries with other brands is not recommended.Hopefully jumping in here is ok.
I currently have one EG4 LifePower4 V2 Lithium Battery – 48V and a single 6000XP. I want to increase battery storage as I tend to run low daily before solar picks up. I have two strings 1680W and 3000W input. I know my initial setup was low on battery capacity and am ready to fix that now. I would like to build a diy battery with 16S 304Ahr cells. I almost ordered a JK BMS but now am hesitant. If I want to keep the rack battery and add a 15kw diy battery is there a preferred BMS? I may add a second 15kw diy battery as well and would consider repurposing the existing EG4 server rack battery if it makes things easier.
Thanks, and if I need to make a new thread, let me know. My title was going to be the exact same so I thought this would be better.
Rick
jk bms and diy batteries work fine with 6000xp, just put the latest firmware on the bms.Hopefully jumping in here is ok.
Rick
Why, what optimizations do you lose?For optimal performance, it is strongly recommended to add another EG4 battery if expanding your battery bank.
If they are the same chemistry and voltage what's it matter? Just run open loop or set one battery to communicate and the others not.Mixing EG4 batteries with other brands is not recommended.
They want to sell batteries and give no pfvcks to anyone who doesnt obey.Why, what optimizations do you lose?
That's a pretty useless post...For optimal performance, it is strongly recommended to add another EG4 battery if expanding your battery bank. Mixing EG4 batteries with other brands is not recommended.
It's completely useless.That's a pretty useless post...
But you know what you are selling.You can't blame them.
I wouldn't recommend other Electrical contractors to my customers, either.
