I was doing some balancing today, and had my 6000xp set for 56.2v charge and 56v float.
Charging from PV. AC charging disabled.
For some reason, the XP let it run all the way up to 59.8v!
I'm sure that's open circuit voltage because my BMS's would have disconnected before then.
Still, when I shut off the PV and checked the batteries (still connected to the XP) they were showing 57v on my meter. Much higher than I set the charge for.
Everyone here already knows it's a terrible idea to run LiFePo4 without a BMS, but this is a great example for the new folks. I can only imagine how bad this could have been if the BMS's hadn't stepped in to protect the cells.
I'm on ccaa-190D0E. I think the latest firmware includes a battery voltage fix. Hopefully that will address this in the future.
