600amp switch placement
Jcain
Would you be worried about putting your disconnect switch that close to Multiplus exhaust fan?20191102_115900.jpg
It wouldn't worry me. Depending on the position of the wire connectors on the switch you might have to run longer wires (not a whole lot longer) so that you can physically get the wire from the switch into the Victron without placing a lot of stress on the connector, but that's not really a problem.
Was advised the two victrons were way to close per spec. Rearranged.
