GavCol
Hi,
I recently received my 8 x 320ah cells from the liitokala store on AliExpress.
So far capacity tests (2p4s for a total of 640ah) have been very promising (but not finished yet ) with capacity meter reporting 615ah.
I just had a question about the method I'm using for compression to prevent the cells bulging.
I have the cells in square with some thin vinyl sheets separating them to prevent friction wearing/contacting the cell walls.
Looking at the pic below, is this setup ok to compress the cells ?
- Can there be too much pressure ? (I can definitely tighten even more but I'm not sure if too much will damage the cells.)
- Does there need to be walls on all sides or just the wider walls ?
Cheers and thanks in advance
Gav
Gav
