6x 195-watt 60-volt panels and one or two Epever 4210 40amp MPPT charge controller(s)
New Orleans burbs
I've been running a smaller 1,200-watt 12v system for over five years but haven't had to figure things out in quite a while. I recently acquired 6x 195-watt 60-volt panels that I want to incorporate into an expanded system. I have two Epever 4210 40amp MPPT charge controllers. Should I do three panels with each CC and keep it 12v or go with all six panels into one CC and go with a 24v system and then use a converter down to 12v for all my existing 12v appliances? I could then keep the 2nd Epever as backup or run both of them and have constant redundancy into a 12v system.
Next question, what is the best way to wire the panels in both scenarios?
In the 24v scenario, the one Epever could be slightly over-paneled with just under 1,200 watts, which is over 1,040 watts. And all six panels in parallel for 60V and around 18 amps total. Is this correct? Then I would need a 24v to 12v step-down converter, right?
In the 12v scenario, the two Epevers could have 3x 195-watt, 60-volts in parallel for under 600 watts, 60 volts, around 10 amps. No step-down coverter would be needed.
The 24v system would mean less PV wire but both scenarios would need multiple splitters from the panels to the main PV wire feed.
From Epever Description -
  • 40amp Solar Charge Controller PV Rated Charge Power: 520W/12V, 1040W/24V. Max.PV Open Circuit Voltage: 100V(92V At 25℃ environment temperature). And has real-time energy recording and statistical and multiple load work modes.
Thanks in advance.
