Starry-Nights
- Nov 4, 2019
- 23
Fast! Ordered on 6/22 arrived Saturday 6/25 via UPS in two boxes. Cells appear perfect, no scratches, no bloat. Checked QR codes; they were manufactured between 8/7/21 to 10/3/21 and all read near identical 3.303V to 3.304V.
I am replacing the eight 100amp 3.2V cells wired 24V in my van and intend to use the existing simple (non-smart) Daly 24V 200amp BMS, Never had any BMS problem and cell voltages have remained the same for the last 2 years. Current battery use is fairly light and rarely goes below 60% SOC, but I often do not used high-draw appliances when cloudy weather forecast - - plus I'd like to add some high-draw items, like air fryer that the new capacity will make possible.
Top balancing: An Eventek 5A regulated power supply is about to arrive, but it looks like it could take a very long time to reach full charge with just a 5A!
Question: would seem I could instead hook up the new bank in series (including the BMS) to my existing solar system and let it charge to say around 95% and then re-configure to parallel for the top-off with the regulated power supply.
Capacity check: I did not purchase any hardware to check this but wonder if I could use the Alai current meter with 350amp shunt already in my system. Seems like once top balanced and full I could install the new battery, re-set the Alai meter to 100% and the new battery capacity. Then with solar disconnected fire up the inverter with around a 1000w load and see how much current gets delivered before the BMS shuts the system down - or I decide to stop it before 2.5V/cell. Think I'd need to check my MPPT setting too so as to allow voltage range. Anything I am missing?
Thanks!
Thanks!
